I am working on a Cobra that seems to be backfiring through the intake on #1 cylinder. It is a brand new GT-40 crate motor. Any ideas what might cause this? Almost everything is new except the injectors. I can here the injectors firing and they are passing fuel. New wires and plugs.
I had the exact same problem. I replaced both the intake manifold gaskets and the exhaust manifold gaskets. The problem went away after that.
All the research I did on the subject pointed to an exhaust leak at the heads, but I replaced both for safety. I'm not saying this is the fix, but it did it for me.
Check that you are using the correct firing order. I've been told that roller engines use the H.O. firing order.
A lean condition causes a backfire through the intake. Be careful lean is bad and destructive. Fix it fast. Check the small filter on top of that injector, sometimes it may get clogged.
Tom
