1 - 3 of 3 Posts
FFCobra Master Craftsman FFR-4618
checked the reverse adapter to make sure it was going the right way, the directions say turn the male end CW and the female end should also turn CW and it did. Placed the adapter on the speedo and so far so good. Then hooked up the cable to it and then tried to turn it by hand to see if it turn but it seems to bind up. Took off the reverse adapter off the speedo with the cable still on the adapter and turned it by hand and works fine. What am I missing? :confused:
There is a flat spacer washer that goes between the adapter and speedo. FFR forgot to ship them with the kit. Call tech and they will drop one in the mail to you. I stripped the gear on the tail shaft finding this out.
Thanks will call on Monday
1 - 3 of 3 Posts
