Hi Again Guys
Are firewall grommets supposed to come with the gauges for the mechanical lines (oil and water temps)
duh!
thanks all!
PaulG
If I remember right there were three of them total I think seperatley packed in with the gauges that they were to be used on. They are all the same size. I also ran the speedo cable and the wire for the radiator fan through one of them with one of the tempature senders.
Good luck.
Too bad all the senders you need aren't included, or even offered. Using mechanical gauges on my modular build has been a royal pain in the butt! They sure do look good on the dash, but I think I'd make a different choice if I did it again.
Cheers, John
Can you get all electric gauges from Autometer, or you get partly mechanical and partly electronic? Mechanical does seem like would be a pain to deal with.
Troy-
