1 - 3 of 3 Posts
OK...any of you with C-4 or C-6 trannys out there...have any of you got any installation pictures you can forward? What types of shifters are you using?
Mid Ohio Loopster
I have a C-4 in mine. Used the stock shifter from a '89 4-cylinder. Recessed it down into the tranny tunnel, so it almost looks like a stick shift. Tranny mount is in a different place than a AOD/T-5 (farther forward). What I did was cut a 1/4 steel plate to bolt to the tranny mount, then set it on the frame mount and bolted it together.
Hope this helps, Scott
I'm running the TCI Streetfighter C6. Absolutely love it, launches hard, shifts great, good for just cruising.
I'm using the Hurst V-Matic 2 shifter, and I don't like it at all! While it looks great, the cable-driven shifts are sloppy or non-existent. I'm probably running about 50-50 on great shifts vs. slow or none, which is not good at all.
One of my winter projects is to move to a linkage type shifter, which I haven't designed yet. I plan to look at some stock shifters and see what's up there.
Hope this helps. If you have any more questions, feel free to zap me a note.
Al
1 - 3 of 3 Posts
