Many people have done a lot of things to make their FFR look more authentic.
This thread is to summarize those changes.
On Old 3850, we made these changes:
1. Hood hoop 3/4" all the way around. ( Don DePontee )
2. Hood latches moved in toward the stripe.
3. Rolled cockpit edges. ( Don DePontee )
4. Hidden trunk hinges. ( Don DePontee )
5. IRS
6. Pin drive rims
7. 15" tires
8. CSX 427 S/C Competition dash layout
9. All Lucas switches (backed by hidden relays so the Lucas switches always work)
10. Single roll bar (albiet larger diameter and front down tube not exposed)
11. AutoMeter "Cobra" guages
12. Wooden English steering wheel
13. Hoops front and rear
14. Hidden bolts, rocker side panel
15. Vintage style seat upholstery
On Project 3105, we are going a little further:
5. IRS
6. Pin drive rims
7. 15" tires
13. Quick Jacks
14. Finishline (decent) louvers
15. Louvers painted body color
16. "ACE" style pedal covers, brake and clutch
17. Mass Flo EFI system (looks like carb)
18. Rectangular tail lights
19. Trunk rounded instead of "perky"
20. Hidden bolts, rocker side panel
21. Vintage style seat upholstery
22. Rivet-on hood scoop ( 65_427_COBRA ) & ( Lancair IV )
23. 4 into 4 headers ( cobrabob99 )
Other Ideas:
24. Dash support tubes. ( Lancair IV )
25. Exposed roll bar (requires moving rear cockpit wall back) ( Jack ffr1846 )
26. "Dropped Butt" mod
27. Different gas tank (less exposed)
28. Different roll bar (smaller diameter)
29. Floor mounted pedals
30. Original style gas pedal.
Of course this list does not address the engine area very much.
Allen ("ACE") English has done some more engine area mods this winter, maybe he will share.
What other ideas did we miss?
31. Less "Bling Factor" ( Jack be Quick )
32. Side pipe finish ( Jack be Quick ) Black or White side pipes. No chrome or silver. ( jperickson2001 )
33. Carpet type ( Jack be Quick ) Wool ( Todd H )
34. Overflow catch can type ( Jack be Quick )
35. Original style throttle linkage ( 2FAST4U )
36. MC reservoirs on firewall ( 2FAST4U )
37. No carpet in trunk ( 2FAST4U )
38. Seat harness cross attachment on roll bar (Finishline) ( 2FAST4U )
39. 427/428 engine ( 2FAST4U )
40. Toploader 4-spd ( 2FAST4U )
41. The gauges are rarely all from the same supplier or the same style; ( Jon A )
42. They often have "label maker" type labels for wipers, lights, etc. ( Jon A )
43. The seats are leather and worn ( Jon A )
44. The paint is never "deep" and glossy... no clear coats, no modern colors ( Jon A )
45. Sunburst wheels (WHY WON'T SOMEONE MAKE REPLICAS OF THESE!?!?!) ( Jon A )
46. Didn't the oil pan on the Cobra's look a lot different 289FIA_Cobra
47. Must have a carb ( cobrabob99 )
48. Small, glass tube type fuse panel on the firewall ( Ed Reynolds )
49. Move the dash hoop back 3/4-1" ( 65' Cobra )
50. Shorter roll bar, I would add thinner tube and angled backwards, but that is quite a task & safety would/might suffer. ( Rickster )
51. Possibly hood vents? I know many of the race prepped originals had these. ( Rickster )
52. Shelby name plates. Shelby emblems (front, back & sides). ( Rickster )
53. Clear front running lights. ( Rickster )
54. Electric fuel pump is inside the trunk on the driver's side trunk wall ( Derald Rice )
55. Spare tire "well" in the trunk floor ( Derald Rice )
56. Battery behind passenger's seat, the long narrow battery ( Larry N. Johnson )
57. Vintage race car look. ( ACE )
58. Good Year large letter tires. ( ACE )
59. Smith & Lucas switches backed by relay's never any problems. ( ACE )
60. Small block 351W with Big block Valve Covers. ( ACE )
61. Turkey Pan, 427 Surge Tank for the big block look. almost... ( ACE )
62. Blue
( ACE )
63. Shave off the turn signal boss and smooth the area with the natural contour like the original so when the turn signal (with a clear lens) is mounted it will point slightly down and out like the original Cobras. ( Don DePontee )
64. Add the correct lip between the radiator opening and the oil cooler opening ( Don DePontee )
65. Weber look intake ( Don DePontee )
66. Rear diff cooler ( Rallygorgo )
67. Rear brake cooling vents ( Rallygorgo )
68. Rear quick jack pickup points (I haven't seen any Coupe replicas yet that have them). ( Rallygorgo )
69. What about Girling front brake calipers. ( Rallygorgo )
70. Floor-mounted brake and clutch master cylinders. ( Rallygorgo )
71. A 40-gallon fuel cell in the trunk. ( Rallygorgo ) ( Todd H )
72. Cooling fans mounted ahead of the radiator. ( Rallygorgo )
73. Rear axles with u-joints instead of CV-joints. ( Rallygorgo )
74. Bent-tube-design front upper control arms. ( Rallygorgo )
75. Putting the side 'gill' openings in the correct place (and correct the angle) ( Mike D )
76. Extend the bottom of the oil cooler scoop. ( Mike D )
77. Deck Lid Hoops ( Lancair IV )
78. Windshield Center Brace ( Lancair IV )
79. Ashtray ( Lancair IV )
80. T-Handle on Shifter ( Lancair IV )
81. Glove Box ( Lancair IV )
82. Mustang shifter ball (flat top, shift pattern in white) ( Rick Terrill )
83. Ignition key to the left of the steering column ( Rick Terrill )
84. Oval hole under hood scoop to match the turkey pan ( Rick Terrill )
85. Leather door latch pull straps on doors. ( Rick Terrill )
86. Ignition switch from mid-60's Ford. ( Rick Terrill )
87. Roll the edges of the body under at the rocker panels ( BS ) ( Todd H )
88. Location of the nameplate passenger's side footbox front ( Charlie C )
89. What about using a quick change rear end in the IRS? ( KC Wildcat )
90. "Fiberglass" foot boxes ( 289FIA_Cobra ) ( Todd H )
91. Differential cooler ( 289FIA_Cobra )
92. FE Cooling Purge Tank ( Lancair IV )
93. Paint the underside of the car Semi Gloss Silver especially inside the front fender above the header and behind the front wheel. Since the cars were aluminum this area was left bare. All the kit cars I have seen have been painted black. This is just a subtle thing to trick the eye. ( COMPETITIONCOBRA )
94. In a 427 S/C body, install a 427 Side Oilder engine ( Todd H )
95. Girling brake/clutch reservoirs ( Charlie C )
96. (Blowby) puke tank on firewall ( Charlie C )
97. Directional lever on the right of the steering column ( Charlie C )
98. Rangoon red with no stripes or clear ( Charlie C )
99. Paint engine bay same as body ( Charlie C )
100. How about a functional Oil Cooler? ( Todd H ) (or Oil Cooler "looking like" it's connected - LNJ)
-Wool Carpeting? (See Item 33.)
-6 pin rims? (Covered by Item 6 Pin Drive Rims that "Look Authentic")
101. Engine moved more forward ( Todd H )
102. Hood prop rod ( Todd H )
103. Correct trunk support mechanism ( Todd H )
- Larger trunk (See Item 71)
104. Skinnier trans tunnel ( Todd H ) (near impossible with the FFR "backbone" frame stiffening)
105. Wider original seats ( Todd H )
- Correct trunk aluminum for the 427 cars (See Item 41, Trunk and gas tank one area)
- Correct trunk aluminium/fiberglass for 289 cars (FFR's are all 427 S/C bodies at the moment)
- Fiberglass foot boxes (See Item 90)
- Narrower body by rear lower doors (See Item 87 )
107. Fix body by front of rear rims & front fenders ( Todd H )
- Aluminum Body (FFR's are painted as were most all CSX cars.)
108. Goodyear Tires (Ha!) ( Larry N. Johnson )
109. Tripod Headlights ( BS )
110. Vintage style license plate ( nc1mike )
111. License plate screwed directly to trunk lid. No bracket, no frame. ( Rick Terrill )
112. Bungee cord over trunk handle and through gromets in lower lip under trunk opening. (Racing models only) ( Rick Terrill )
113. 1. Soft top and/or snaps & door ferrules. ( DavidT )
114. Rookie stripes. ( DavidT )
115. Extended hood scoop. ( DavidT )
116. Hood scoop "grille" (perforated sheet metal). ( DavidT )
117. Headlamp rock guards/grilles. ( DavidT )
118. Oil cooler lines should be black fabric hose. ( DavidT )
119. "Kidney Bean" wheels. ( DavidT )
120. Quick jacks should be two-piece & welded with the correct mounting points & shape. And, the sleeves should be shortened. ( DavidT )
121. Side exhausts should be longer. They should extend to just before the front of the wheel arch. ( DavidT )
122. Under-car exhaust. ( DavidT )
123. Trunk rack. ( DavidT )
124. Wire wheels. ( DavidT )
125. Grille bar/splitter. ( DavidT )
126. Wind wings. ( DavidT )
127. Plexi visors. ( DavidT )
128. Relocated gas cap (behind passenger area). ( DavidT )
129. Hood louvers -yes, many race cars had them. ( DavidT )
130. Single drivers "race seat." ( DavidT )
131. SCCA & SAAC decals (windshield). ( DavidT )
132. SCCA tech inspection decal (roll bar). ( DavidT )
133. 'USA' euro badge/decal on trunk. ( DavidT )
134. Racing windscreen. ( DavidT )
135. Spats! ( DavidT )
136. Door hinge covers. ( DavidT )
137. Raydot or Talbot mirrors. ( DavidT )
138. Rotunda or Sun short-sweep tach. ( DavidT )
139. Door frame aluminum trim (Dark Water). ( DavidT )
140. Rubber shift boot. ( DavidT )
141. Fire extinguisher. ( DavidT )
142. Hoop mounted grab handle. ( DavidT )
5. IRS
6. Pin drive rims
7. 15" tires
5. IRS
6. Pin drive rims
7. 15" tires
13. Quick Jacks
Other Ideas:
62. Blue
