FFR Builder
I just unpacked the proportioning valve that I bought from Ford. I looks like it is set up to use bubble flairs. The package includes an adapter that converts the bubble flare to a double flare. The problem is that the adapter relies solely on threads with a seal compound to keep the brake fluid from leaking. It seems to me that the adapter should be using a mechanical seal and not just some compound on the threads. What should I do to insure that this will not leak? Thanks, Dave
If it's this valve, the ports are NPT, not bubble flares. That's why there's sealant on the adapters.
FFR Builder
Joe,
That's the one I have. I am surprised that the sealant will handle the high pressures that a brake system will see. I guess if thats how this part is designed I will run with it. Thanks for the information! Dave
They are tapered pipe threads, so they'll take significant pressure if properly sealed, and Ford has taken care of that for you. The sealant is actually a type of Locktite, so install and don't worry.
I used the newer FMS valve but I picked up some 90 degree adapters that were pipe thread to inverted flare and placed the valve under the dash. I have the brakes bled and all is good with no leaks.
Paul
FFR Builder
Thanks guys. The valve is installed. Paul, I put it in the same location as yours, except I mounted it under the crossmember.
Thanks again,
Dave
