1 - 3 of 3 Posts
I bought a Griffin Radiator for a fox mustang. It came in and the measurement is 27 1/2 x 18 inches. Is that correct. When put up to the front of the chasis it hits on the filler neck when moved to the left far enough to move the upper hose neck to the outside of the mount. Any suggestions would be appreciated. The standard radiator for the fox mustang was 30 inces wide.
Discussion Starter · #2 ·
No-one has dealt with this issue? I guess that makes me a pioneer, or an idiot. Sounds like mod time.
I have the 27.375" wide with the filler right under the frame and I routed the hose to the inside and above the X member. I'm using the convoluted stainless flex hose. If I did it again I would have gone a size wider (making sure to get one with tapered bottom tanks to clear the frame) to move the cap out from under the frame or just order one made just for the car from a vendor. Mine was a Summit brand radiator.
summit radiator
[ July 13, 2007, 11:07 AM: Message edited by: Sanford ]
1 - 3 of 3 Posts
