Original vinyl is flopping off. Would really rather just cover it up. I know Herb has them for Mark II & III, anyone have them for Mark I's?
Otherwise I might try my hand making them.
FFCobra Captain
I have the MK1 style door hinges & doors and Herb's panels fit great.
I think they are. Mine look different than the others I have seen.
Dan/Larry, does your door have the aluminum panel at the top?
I have chassis 1343 I think, it's a very early one. , with the aluminum skin that is covered with vinyl.
FFCobra Captain
My doors were fiberglass inner & outer halves. It doesn't sound like mine are the same as yours. You can probably cut a template out of paper and send it to Herb to see if it will fit your door. My panels are just held on with industrial strength velcro, so they are easy to fit.
I thought they might be different. Thanks. I will take a pic and send to Herb to see if there is anything he might be able to work up.
You have the earlier style MKI Doors. The later MKI Doors are Fiberglass on the inside. Definately give Herb a shout....if he doesn't have anything maybe you can mock up a door panel and have him upholster them.
