I tried installing the brake hose that came with my CNC reservoirs onto the npt fittings. I can get them on about 3/4 ways and that's it. I tried heating the hose in hot water, but didn't notice a difference. My thumb and fingers were sore from fighting just one hose and it's not fully seated.
Can I apply any chemicals to make it slide better? (brake fluid? soapy water?)
suggestions?
Aeroquip sells an assembly lube as does other hose manufacturers. That’s what I used.
Jack
Hose and brake components lube
suggestions?
MP: Jesus, don't use soap and water. You don't want water anywhere near your brake fluid.
Try brake fluid first on the hose and nipple and if that isn't enough, try this stuff. It is compatible with brake fluid and is available at NAPA and most auto parts stores. It is great on "O" rings and things that need to be slippery when you assemble them. Use just a thin coating.
NAPA AUTO PARTS
Ron
Back when I was wrenching on cars for a living we used a brake system specific assembly lube when rebuilding wheel cylinders and calipers. If its still available, that would be your best bet if the brake fluid doesn't do it for you.
mark you will find the hoses may not be long enough too
well they were not for my wilwoods
go to SCP and change out the fittings at the bottom and install 4AN i believe that was the size i used, i then got some stainless fluid hoses make sure they work with brake fluid should be a 1/8 or 1/4" npt fitting at the bottom of the reseviors
good luck, buzz by the house i will show you my set-up
