1 - 3 of 3 Posts
Have Kit Will Build
I only received 1 spring washer for the DD upper steering shaft - what function do they perform when installed? With the 1 washer in I still have a fair amount of play between these 2 shafts (DD). I can't see that the other washer would fix this. Is there some other adj. to tighten? Thanks!
Have Kit Will Build
I only found 1 in my pkg but I may have dropped it and didn't see it - is the play in the shaft normal?
1 - 3 of 3 Posts
