1 - 16 of 16 Posts
· FFCobra Fanatic
Thee are several, FMS sells the RDI blocks, prices are around 3K. Mike Forte had an aluminium 302 block, I think he wanted $2200 for it.
· FFCobra Fanatic
Roger,
The FMS blocks, 302 c.i., weigh about 50/60 lbs less than a stock block, closer to 100/110 than the R302's.
· Super Moderator
Hotshot-
I believe there is an aluminum 351W. Ford is planning on using one in their soon-to-be-released GT40 for 2003 or 2004. You may have to contact your local Ford parts man for the part #. Expect to pay some heavy $$, around $4K.
-Keith
· Premium Member
Here are some pictures of a FMS aluminum block ... 4 bolt mains. The raw block (before machining) weighed 92 lbs. It took 4 months to get the block from Ford. I was told they are in short supply at certain times of the year. The pain in the wallet doesn't stop ... because of the four bolt mains it requires a custom oil pan. I'm still working to install the SDS ECU so its not running yet.
347 Stroker - 1
347 Stroker - 2
· FFCobra Fanatic
Luis,
Yep, FMS has a 351 alum. block. The 302's were hard to get because the outfit that makes them made some revisions to their design, in the lifter area,I believe. I thought that most of the alum FMS stuff was made by Alan Root.
· FFCobra Craftsman
Correct me if I'm wrong, but every SB aluminum Ford block I've seen is a siamese(sp?) cast and recommended only for race applications. The old man (CS) makes a big block but that comes complete and can be had for about a years pay.
· Super Moderator
CS does make an aluminum big block, but its the FE series with improved oiling (the old side-oilers were terrible things). Cost is $4K
Keith
· FFCobra Fanatic
The 400 C.I. small block Chevy is a siamese bore, and talk about ass kicking engines. Fear not, be brave, aluminium blocks and steel liners= good times.
· Senior Charter Member
CLL MIKE FORTE HE HAS WON I KNOW HE WILL SELL IT CHEAP HE HAS THE BLOCK ONLY BUT HE CAN GET ALL THE PARTS NEEDED
Here you go :D :D :D :D
http://re-racing.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=RE&Category_Code=11591
Ford Racing 351 Aluminum Wet or Dry Sump Block
Code: M-6010-F87
Price: $3,295.00
Ford Racing 302 Aluminum Wet or Dry Sump Block.
396 CID Capacity, 8.700" Deck Height
Code: M-6010-X352
Price: $3,295.00
Ford Racing 351 Aluminum Wet or Dry Sump Block.
427 CID Capacity, 9.200" Deck Height
Code: M-6010-X351
Price: $3,295.00
Code: M-6010-Z351
Price: $3,295.00
454 CID Capacity, 9.500" Deck Height
Or how about the new DART block?
http://66.96.130.106/archives/2002/04/dartblock/index.shtml
Cylinders may be bored to 4.185", still maintaining a 0.250" wall thickness!!! :D
and 193 lbs!
Andy
1 - 16 of 16 Posts
