Hi,
I have made my own low mount front air lift system to use with factory shocks and tried it on one side yesterday. It took about 22sec to lift the front up around 2” and I wish to decrease the lift time as much as possible. What compressor do you guys use to have the lift time as low as possible?
Thank you
/Johan
Hi,
Thank you
/Johan
My Stance Air Cup kit came with a Viair compressor and takes probably 5-6 seconds to fully extend(lift) the front end.
Great info, thanks. Do you know which Viair compressor model you got? Is your kit low mounted or did you rebuild the upper shock brackets? To bad the shocks won´t work upside down. It would have saved some time :)
Regards
/Johan
I was hoping to solve the issue without a reservoir due to the lack of space. But if a bigger compressor wont help I have no other choise.
Thank you
/Johan
You do not need a tank, at least with the Tankless Front Kit from Stance Parts you don't.
Here is a link to the Tankless setup with a Viair 400c Compressor Setup. With the Tankless kit there is a pressure switch on the compressor output line that once the system is pressurized (car lifted) it shuts the compressor off.
