Have Kit Will Build
Anybody using an Autometer Air/Fuel ratio gauge? Is it accurate? Says only works with 'narrow band' oxygen sensor. Can I just go to the parts store and ask for one? Where does oxy. sensor go if I don't have one - will be running 4>4. Thanks!
Narrow bands are a bit out dated, but detter than nothing. Yes, you can go to the parts store and get a standard single wire o2 sensor. If you haven't already bought one, look into an Innovaite wide band. it is worth every penny.
I have a nearly new one if you are looking to buy a Phantom series one. pm me if interested. I ended up not running it because I swapped in an accelerometer instead.
Agree with Jeremy on getting a wide band instead. I use Inovative but there are others. Basically a norrow band will just show you rich or lean of 14.7-1 afr,but not by how much. Wide band will show the amount of rich or lean above this in actual afr numbers or lamda value's. You can also use a Autometer wide band guage to see the read outs from a wide band.
Best to buy a unit that will record while you drive. After your drive, review and also have a record to compare to when making changes. Not easy to watch flashing numbers on a gauge while driveing.
Bought my Inovative unit from Wayne(cool parts) at a good price.
There's nothing wrong with a narrowband sensor for it's intended purpose, but it isn't right for measuring fuel ratios away from 14.7 or 1.0 Lambda. For what you want to do, a wideband unit with the correct sensor is needed. The Innovate unit is hard to beat for the price, but there are other choices out there too.
Have Kit Will Build
OK - I understand some things better now. I was looking in to this because I had a chance to buy an Autometer gauge, which matched the gauges I already have, for a good price. But I see that it may not really give me the info I would desire anyway - and now I see why it might be priced low. Thanks all!!!
