1 - 3 of 3 Posts
Do I want to use the front mounting holes or the back on these radiators? I mounted mine using the front holes but this seem to put the cooling fan on top of the little nub on the steering rack. I have also had to trim my radiator aluminum pieces to get them to fit. What has everyone else done? I was thinking about using the rear mounting holes to see if this gives me more clearance. I guess next step is to test fit the body.
Thanks,Q
I used the front holes on my afco.I bought a piece of 1/8 thick alluminum 5/8 inch wide to reinforce the flange lip that is bolted to the frame.. I also had the clearance issue. I adjusted that nub on the steering rack with a mallet.
Discussion Starter #3
How well did the bottom aluminum piece fit from the radiator to the body?
Thanks,Q
1 - 3 of 3 Posts
