i'm using the AEM with Waynes stack system. Works great! Great price you have on it BTW!
FFR2370,
What did you use for the harness with the stack system? Did you make your own?
Charlie
Charlie,
I think the one Hotshot is selling uses a 88-93 Ford EEC-IV harness, it just plugs right in and uses all the 5.0 sensors and everything. For a Stack setup you will need to use a MAP sensor instead of the Mustang's MAF, I bought the 2bar one from AEM. So if your using a the donor Mustang wiring and EFI currently all you need to do is plug in the AEM ECU, change the intake manifold to a Stack setup, wire in (3 wires) the MAP sensor and fire it up! Also AEM has a great support forum http://forum.aempower.com/bbs/index.php. Also this ECU has traction control capabilities!
I'm not connected with Hotshot or AEM in any way, just a satisfied customer.
