I am looking at the adjustable seat track from Summit Racing for the drivers side. Will the hole pattern line up with the 4" round tube and the 2 x 2 square tube for mounting.
Here is a nice one that Breeze sells that you rivit to the floor pan and don't need to be dead nuts on the 4" round tube. It is a little pricey but good quality and ease of installation.
Mark is extremely easy to work with and will back any product that he sells.
Check it out here:
http://www.breezeautomotive.com/details.php?prod_id=160&cat_id=10
Hope that helps,
Todd
That is for shure the best set of brackets on the market but a little pricey for something Iam going to cover with my butt.
I used them on both sides. I added 5/16th carrage bolt to go where I wanted them(not just through the aluminum). It was easy, took the track apart drilled where needed, tack welded bolts in place. I left the original bolts and used fender washers just because. I mounted the tracks to brackets on the outside of
Kirkeys, so I had no control over where they ended up.
