1 - 11 of 11 Posts
Looking for this as well. Currently talking w a company that makes a long C5/C6 tubular UCA about a set to make 1.5” shorter than stock. -- no direct luck but they have the tapered slugs.
EDIT: Picked up the SPC parts, 4" and 5" threaded sleeves, the racekit with the inners, balljoint plates to weld those tapered slugs to match up to the C5 spindle balljoint. Will document if/how this will work out, should be over the next few weeks.
Parts arrived from SPC.
The cylinders w C5 taper came from Parts Shop Max.
For inner mounts it is needed to fabricate or find a source for GTM/C5 dogbone to bolt-through conversion.
362056
Do you happen to remember which ball joint plate you used?
1 - 11 of 11 Posts
