hey all, can someone give the part number of the serpentine drive belt. Small block, with reverse rotation water pump and power steering. March brakets and stock pulleys.
Thank you
Brian.
363627
363628
Probably not. Get some string, run it around where the belt will go and measure it. Go to Advance or ? and buy that length, 2 shorter and 2 longer. Keep what fits and return the others.
Too Cheap to paint!
Brian,
The measuring way is the best.
But if you want, I have a bunch of belts you can have, I can check the lengths if you are interested
Thank you everyone for your help. Dan, ill measure it (belt, haha) and see if I can find something on Daycos website. I took off a Dayco belt when I added power steering, so the first few numbers on the belt should lead me in a good direction.
Thank you again everyone
March performance should have the belt length figured out for ya. I have that set up for a 351W. I'll send the belt number when I get home.
I have the same exact set up as you and my belt is NAPA #060680 which is 13/16" x 68-5/8". Hope that helps!
