1 - 3 of 3 Posts
Hi, I am trying to mount the accelerator pedal an running into a few glitches. I think:
1, I don't have the template that ffr supplies
2. When I seem to get the pedal where I want it it bottoms out on the right side of foot box (without carpet or insulation)
3. When I move it to the left it interferes with the brake. Specifically the wildwood arm contacts the connector on the top left of the pedal.
Is the bracket supposed to be mounted on an angle somewhat? Any suggestions?
Thanks!
Electronics Machine Metal
No reason you can't angle it to make it fit and work clear properly. The only part of the pedal you see once the car is finished is just the bottom part of the pedal anyway....and it's already at an angle, so adding more angle to clear the brake pedal and alum panels won't stand out.
1 - 3 of 3 Posts
