Does anybody sell the AC gas pedal? I just see them in two's for the brake and clutch.
Also how are these mounted? easy/hard. Any welding involved? As always thanks for your response. Richard
Richard,
Most of the vendors sell them in pairs. There is an FAQ on how to install them. Briefly, you have to cut off the old pedal pad around the pedal arm, carefully hack saw a slot in the A/C pedal's mounting stub, then mount the pedal on the pedal arm by drilling a hole through both. Some people don't do the slot, they just drill and mount. I think the slot is a better approach but just an opinion.
I did it and it took some time. IMHO, I'd rather have Russ Thompson's pedal covers. These are drilled brushed aluminum.
I have an extree on that you can have...
I was going to do the cutting of the slot on mine, but decided to just drill them and bolt them on. I went that way because it allowed me to space the petals further apart without having to do the petal bending mod.
Wayne
BTW - I bought two pairs. Did all three pedals and made a dead pedal with #4.
I drilled hole, then slotted with a grinder; worked well.
