I have noticed a number of brackets, dash end plates and interior parts that could be made with ABS plastic. ABS is fluid at around 225C, so there are limits to its application close to high temp sources in the engine bay, transmission and brakes (but I was going to try ABS sensor brackets and see how it went).
I have an ABS printer (Makerbot Replicator) and am happy to print parts for a (time permitting, it usually takes several hours per piece..!) and develop a catalog of one off or reusable designs for the Coupe..
I use Sketch Up for 3D designs and mods. Its a free download. Or if you have some experience in this area, the build files are in .stl format. STL files are only editable with much more expensive software.
The Replicator build platform is about 210*120*150mm high so break down parts to fit these parameter.
Look forward to hearing from you.
Cheers
Chris
Cheers
Chris
