Was hopping that I could get a measurement of someones Victor JR and Holley setup to compare height. A measurement from the manifold bolt indicated by arrow to the underside of the roadsters body near the windsheild would be helpful too. Thanks in advance
Jon D.
Discussion Starter · #2 ·
ttt
ttt
This isn't exactly what you asked for, but here is the F-28. When I test fitted it using convertable mounts I had another 2" of room before running into hood clearance issues.
Rickster
Thank you that will work great. I just wanted to prove to a friend that this setup would work.
Since the RPM AirGap manifold is only 15/16" taller than your setup that would mean I should have about 1-1/16" clearance.
Jon D
