1 - 3 of 3 Posts
I have a stock '95 5.0 engine that I am going to use in my build. I bought the FFR/Ron Francis CHASSIS harness, and now I'm trying to figure out the best/easiest way to handle the engine harness.
After doing some research, it sounds like the '93 and earlier computer is much more tolerant of changes than the '95 computer.
So, if I were to order the 'Stand Alone EFI Harness' from FFR, along with a A9L computer, would it all hook up to my '95 engine ? Or are the connectors going to be different on the accessories, sensors, etc that are on the '95 engine ?
I'm going to remove the smog pump and all associated stuff - in Wisconsin it sounds like I don't need to pass emissions with a hobbyist plate...
Thanks !
section 8
That should work fine , be sure to add a fusible link or fused wire to power the eec . Bob
1 - 3 of 3 Posts
