1 - 10 of 10 Posts
Was the 90 a roller? I had an 87 Marquis engine in my Cobra when I first built it. 180hp. Non roller, the timing matched the non-rollers (I think 351 matched it) and the intake faced the driver side.
might want to check and see if the Crown Vic is an HO or non HO
ASE Tech & Shop Teacher
I think you can flip the intake to face the passenger side, no problem., costs a gasket.
I don't think it is, and hence will not make the 225 hp the HO motor did.
I think I know because I own a locked up 5.0 from a similar Lincoln, and priced a stock rebuilt motor, interestingly, a rebuilt Mustang 5.0 HO motor was only a dollar more than the non-HO.
I think the block in the Lincoln may be roller capable, but might have a non-roller cam in it.
BUT DON'T RELY ON MY THINKING, CHECK IT OUT!! K?
Normally the CV motor uses a smaller throttle body, lower rated injectors, different firing order, lower flow intake and I think smaller valve heads.
The injectors will be 14#, a non H-O roller camshaft, smaller upper plenum inlet, 55MM T-Body and EGR spacer, speed density, non H-O firing order and injector sequence. Flat top cast pistons without valve reliefs. '86 Mustang style high swirl heads. 150HP or 155/160HP with dual exhaust. Non H-O computer. It can be built anyway you want.
New Member
Thanks for all the info guys. I saw the engine for sale on Craigslist, and have been looking for an '87-'93 Mustang engine to tear down and rebuild as a shop project, now that by car is done. Shops always look better when there is something going on in there. Plus, I miss the daily adventure into my shop!!
Thanks again,
Dave H
The HO in the Mustang is a different engine than the non-HO found in the CV. For example, the firing orders are differant. For the cost differential, I'd look for a HO. Check the local bone yard, usually can pick one up for under $500. HTH.
-SGC
1 - 10 of 10 Posts
