1 - 3 of 3 Posts
Caress of Steel
Will an 85 pedal box and filler neck work? They look the same as the newer parts, except the clutch pedal has a little metal tab up near where the safety switch would be.
Bunkie musta cleaned out the last 87-93 pedal box from Bonneville salvage! (BTW, dude, lemmee know when you want me to get that body buck outta your hair...gonna need it sooner or later!)
Joe,
Charlie had one last fall. Not sure if I will use the buck again, might build a smaller metal frame for the bodywork. Which you can use of course when your ready. Could leave the buck at the height it is now that way.
yes, they both will work.
but the gas tank from an 85 Mustang will have a fuel level sending unit that does not work with the vintage autometer gauges...wrong Ohm range.
1 - 3 of 3 Posts
