Has anyone installed power brakes (booster with Master Cylinder) on their Daytona? I know the space is tight, but would like to improve my braking.
Thanks - Ron
Thanks - Ron
I too have used the Wilwood big brake setup on several builds. They came with BP-10 compound pads and likely that's what you have. Something to confirm. I've been happy with mine. Some change to a BP-20 though. More aggressive. Maybe call Wilwood and see what they say. Maybe there are other choices. But feeling marginal and spongy? Need to pump them? No way. Something is wrong. This should never be the case. You still have air in the system, something defective, leaking, whatever. You have to get that resolved before even thinking about power assist. You're potentially covering up a problem. Many don't recommend power assist on Wilwoods anyway.Thanks for the information. Mine is a Gen 2 and it has the four wheel disk Wilwood big brake setup including the pedals. Can you recommend a more aggressive pad? The car has about a 1000 miles on it and I would say they are broken in/bedded. The brakes are marginal and feel a little spongy. I usually need to pump them a bit before braking and cornering. I've bled them, but doesn't seem to make a difference.
John Dol - I would be interested in learning more about what you did to put a booster on your car.
Thanks for all your help...really appreciate it!
You still have air in the system. Wilwoods can sometimes be a PITA to bleed. I like to use Russell speed bleeders. Makes the job quick and easy. Fix this problem before moving on to anything else. Until the system is completely purged, nothing will improve it. You'll just be wasting time and money.Thanks for the information. Mine is a Gen 2 and it has the four wheel disk Wilwood big brake setup including the pedals. Can you recommend a more aggressive pad? The car has about a 1000 miles on it and I would say they are broken in/bedded. The brakes are marginal and feel a little spongy. I usually need to pump them a bit before braking and cornering. I've bled them, but doesn't seem to make a difference.
1/4" x 28. 639540. You'll need 4 of these; two bleeders per caliper.Do you know what size or p/n Russell speed bleeders I need? BTW, I have the BP-20 pads on order.
The spec sheet for the Factory Five big brake options calipers list these as the bleeders: Wilwood Disc Brakes with 1/4-28 Bleed Screws. Very common size and lots of options for speed bleeders. I'm sure that's a good process or Bob wouldn't have recommended it. I have, however, had no issues with pressure bleeding your exact setup with no air after a couple of times around. Like speed bleeders, it's a one person operation.Do you know what size or p/n Russell speed bleeders I need? BTW, I have the BP-20 pads on order.
This is what I used:Thanks for the information. Mine is a Gen 2 and it has the four wheel disk Wilwood big brake setup including the pedals. Can you recommend a more aggressive pad? The car has about a 1000 miles on it and I would say they are broken in/bedded. The brakes are marginal and feel a little spongy. I usually need to pump them a bit before braking and cornering. I've bled them, but doesn't seem to make a difference.
Whether vacuum or hydroboost. How new are they and have they been thoroughly broken in/bedded? In any case, what brakes do you have currently? Lots of options to upgrade brakes or even easier upgrade the pads you're using to something more aggressive.Has anyone installed power brakes (booster with Master Cylinder) on their Daytona? I know the space is tight, but would like to improve my braking.
Thanks - Ron
