1965 Factory Five 65 Coupe
Built by Midwest Customs and Classics-This was their show car for several years. Original asking price of $82,000.00 Purchased at Barrett-Jackson in January 2008
Engine:
• 392 CUBIC INCHES 475 HP CRATE ENGINE REAR SUMP
• M-6007-C392RT
• 392 cubic inch
• 475 hp @ 5600 rpm
• 495 lb.-ft. @ 4400 rpm
• 10.0:1 compression ratio (nominal)
• Forged pistons
• Forged steel cap screw connecting rods
• Hydraulic roller camshaft, .580" lift intake and .602" lift exhaust, duration at .050" is 232 degrees intake and 240 degrees exhaust
• Double roller timing chain set M-6268-A302
• Forged steel crankshaft
• High-performance T-sump oil pan
• Ford Racing aluminum "Z" cylinder heads M-6049-Z304DA with 2.02" intake valves and 1.60" exhaust valves
• Roller rocker arms M-6564-F351
• New heavy-duty 5.8L �Sportsman � block, oil and water pumps, performance oil pan, steel billet flywheel and high-performance harmonic balancer
• Firing order 1-3-7-2-6-5-4-8 (5.0L HO and 351W order).
• Imagine injection fuel system intake manifold
• DeatschWerks tuned injectors
• DTAfast S100 Pro Fuel and timing ECU
• Crank fire DIS with D585 LS2 coils mounted on valve covers with custom aluminum covers
• Innovate LC-1 Wideband O2 sensor
Transmission:
• Tremec TKO500
Suspension:
• SN95 Spindles
• Gordon Levy custom Koni 3012 shocks
• Eibach springs front: 550 rear: 350
• Vintage Performance 3-Link sway bar kit
• AGR 15:1 ratio custom power steering rack with aluminum rack bushings
• bump-steer kit
• SAI Mod kit from Whitby
Brakes:
• Ford Cobra brake calipers
• Hydroboost power brakes
• 13" front and 11.65" rear rotors
• Hawk HPS front pads
• Porterfield R4-1 rear pads
Interior:
• Kirkey Road Race seats (Driver's side on double locking sliders)
• Simpson 5 point harnesses
• Russ Thompson gas pedal
• Fire extinguisher
• Vintage Air
Exterior:
• Blue with white stripes
• Molded in rear spoiler
Wheels and tires:
• Team 3 AC-III 17x9 fronts
• Team 3 AC-III 17x10 1/2 rears
• Kumho Ecsta XS 275/35-17 front 315/35-17 rear
We have had a lot of fun with this car over the past several years. It is a blast to drive and everywhere it goes it draws a crowd. It is time to move on to the next project so that is why it is being offered for sale.
Email me with questions or for more details
[email protected]
$55,000.00
Located in Oklahoma City
More photos here : daytona pictures by fmcokc - Photobucket
