1 - 3 of 3 Posts
$45,000
Click here for more pictures.
Features:
  • 11,500 Miles
  • Ford Racing Universal safety bellhousing
  • Tremec 3550 5-speed transmission
  • 1994 8.8 Mustang positraction differential (4:11)
  • Autometer Ultra-Lite gauges:
  • 5" tachometer and speedometer;
  • 2 5/8" water temp, oil pressure, oil temp, fuel and amp.
  • Aluminum radiator and fan shroud
  • Tubular upper and lower control arms
  • 1/8" steel plate under driver and passenger seats
  • Flaming River rack and pinion steering
  • K&N XStream custom air cleaner
  • Thermostatically-controlled radiator fan (adjustable)
  • Coil-over-shock front and rear suspension
  • Pan hard bar
  • Full aluminum rear inner fender panels
  • Aluminum under hood panel
  • Quick disconnect steering wheel
  • Kirkey racing seats for more seating space
  • Stainless steel fuel tank straps
  • Stainless steel flexible brake cable
  • Aluminum steering shaft cover
  • Custom made door panel
Engine:
  • PRECISION MACHINED 351W BLOCK
  • MICRO-POLISHED & DEBURRED NODULAR CRANKSHAFT
  • SHOT PEEN HARDENED & STRESS RELIEVED CONNECTING RODS WITH 190,00 PSI ARP BOLTS
  • HYPEREUTECTIC HEAVY DUTY PISTONS 9.7 TO 1 COMPRESSION
  • H.O. CRANE CAMSHAFT DELIVERS MID-RANGE HORSE POWER AND EXCELLENT LOW END TORQUE
  • NEW MELLING OIL PUMP AND SCREEN
  • EDELBROCK RPM ALUMINUM HEADS 60cc COMBUSTION CHAMBER
  • 2.02 STAINLESS STEEL SWIRL POLISHED INTAKE VALVES
  • 1.60 STAINLESS STEEL SWIRL POLISHED EXHAUST VALVES
  • EXTREME DUTY TRUE ROLLER 1.6 RATIO ROCKERS
  • HARD SEATS FOR UNLEADED OR REGULAR FUEL
  • HEAVY DUTY 1.45 DIAMETER VALVE SPRINGS, 7 DEGREE LOCKS
  • NEW HEAVY DUTY CHROME MOLY PUSH RODS
  • NEW CHROME FRONT SUMP 5 QUART OIL PAN
  • FORD PERFORMANCE POLISHED ALUMINUM VALVE COVERS
  • HEAVY DUTY SFI APPROVED STANDARD FLYWHEEL
  • NEW EDELBROCK PERFORMER RPM DUAL PLANE INTAKE MANIFOLD
  • NEW 4 BARREL 800 CFM EDELBROCK CARBURETOR WITH ELECTRIC CHOKE
  • HIGH VOLTAGE ELECTRONIC DISTRIBUTOR AND COIL
  • NEW FUEL AND WATER PUMP
  • CHROME ONE WIRE HOOK UP 100 AMP ALTERNATOR
  • MARCH POLISHED PULLEYS AND CHROME BRACKETS
  • BALANCED, BLUE PRINTED, ASSEMBLED BY ASE TECHNICIAN
1 - 3 of 3 Posts
