1 - 3 of 3 Posts
I was a little disappointed today to see the reading of the bump steer. Now when it comes to adjusting bump steer I can not claim to be a professional in that area. However for a quick note of what I saw is that after maxing out my rear tie rod adjustments I was still getting more toe in than I wanted. For the front I was more angered. Instead of toe out on compression I was getting toe in and not able to correct it. Any tips out there? From what I see the steering rack would need to be lifted higher. Anybody what to help me out on this one?
Are you trying to make adjustments with the FFR stock tie rod setup?
If you are just dont bother trying to get decent numbers.
I installed the FFR front bump steer kit and for the rear used an aftermarket Corvette system
I am more than happy with the results
1 - 3 of 3 Posts
