1 - 2 of 2 Posts
Anyone in the Atlanta area that has experience with aligning these with an electronic alignment machine?
If not, any of the builders have specs they use to set these up?
Thanks!
Luthersnake,
You do a regular front end alignment. The rear is a solid axel therefore when you adjust the panhard bar I measured from the outside of the 4" frame to the inside of the rear tires (rim). HTH
Take care,
Ron
1 - 2 of 2 Posts
