21 - 31 of 31 Posts
The pin going through the oil ring is a non issue. There is a steel support ring that goes on before the oil ring. The piston does not drop further out the bottom of the block, so again a non issue. A general observation is that a "stroker" engine will consume a small amount more oil than a stock engine. I will contribute this to the fact that if built correctly for high performance use they will have slightly looser clearances than an OEM engine, especially if they have forged pistons. A lot also depends on the quality of the cylinder finish and piston rings. I know Ralph Button runs 347s in his Roadster and has accumulated over 600,000 miles.
My 347 is indeed built with looser clearances as described above. It uses 20W-50 Valvoline Racing oil with zinc additive.
The main girdle was machined down in several places for clearance. (The girdle was made for a high-rpm 302.)
My Mk3.1 is also 347 equipped. Avenger aluminum heads, engine built by Ford Performance Solutions (which is a different name now) in Anaheim, CA.. I have the dyno sheets somewhere showing about 400hp. I'd like to build a 427 someday, but in the meantime this seems to be able to get me to coffee at Tim Hortons on time.:D
Discussion Starter #24
Love Tim Hortons coffee there was one right outside the gates of Selfridge in Michigan. Being low man on the totem pole I ran for a lot of coffee. Lol
I'm loving hearing from the people of the 347 club!!
I have a FordStrokers DIY (I did the assembly) 347. TrickFlow 185 CNC heads, Weisco custom pistons, SCAT crank and rods, Custom grind Comp cam (.579 / .576 - 282 / 292), Victor Jr and a QF 750 Q series carb. 500 fwhp.
Discussion Starter #26
I kinda wish I would have gotten a little bigger heads. I have 170 TFS.
Awesome! Sounds like a beast!!
Discussion Starter #27 (Edited)
This is mine with oil pickup and windagetray
Saw where you had the Inglese for sale. Why did you go for the Borla? Vacuum?
I had the Inglese on initially and didn't have enough vacuum. I'm not the smartest knife in the drawer and had I been smarter I would have just changed out the FAST Easy EFI for the Fast XFI Sportsman system and left the Inglese stacks in place. Saved a lot of $$$ as well! The FAST Sportman system allows you to adjust all aspects of the system whereas the FAST Easy system is self learning but it needs the vacuum! The Sportsman system is a real learning curve for myself. I'm currently taking online classes with HP Academy to learn the system and how to tune the engine.
Dave
My car was finished 10 years ago with a 347 that I built. Only 5000 miles on it getting ready to switch to FiTech system. don't have any idea what the horsepower is, very strong and very fast motor, dependable, I love it.
21 - 31 of 31 Posts
