Guys,
I am building a crankcase breather system for my Spec Racer and I need to have measurements from the back of the valve cover to the firewall. Pictures would be nice as well if you have them - they should be straight down shots (man am I picky or what?).. :rolleyes:
Anyways - the measurements should be from the widest part of the Valve Cover directly rearward.
The idea here is to bore a hole in the back of the valve cover and install a -10 AN fitting where I will hook up a 90 degree fitting and hose to go to the external breather tank.
Thanks for your help!
You could use -8 or probably even -6 for this. Cheaper and easier to work with unless you already have the -10 fittings / hose.
-10 is some BIG stuff.
I always use -10 for breathers and -12 for oil lines. The idea is to have as little restriction as possible and let the chambers in the breather tank handle the separation duties.
Remember that this is for a racecar and it will be seeing higher RPMs for extended periods of time - particularly if we run it in the 25 hour race.
Thanks!
Shameless bump....
I would hate to punch holes in a set of COBRA valve covers and have them be in the wrong spots. :(
Anyone?
Stock LX donor covers - 5" from the back to the fire wall - driver's side.
Hope this helps
F-A-N-T-A-B-U-L-O-U-S ! ! ! ! !
That was
precisely
what I was looking for!
Thank you VERY much!
