21 - 24 of 24 Posts
Too Cheap to paint!
I've been through four engines so far, from the worn-out donor 5.0, a crate 302/340 HP (Split wide open after four years of heavy use), a mild 331, and now my "BiG" 331 (465 HP).
I would vote for a very mild 331, so you get a little more easy torque, and go mild on the parts. Torquey cam, AFR 165 heads, Dual-plane intake, you are good to go.
Wholly Cow! 4 engines good God man! Driving hard having fun!!!!!!
Too Cheap to paint!
Well, um, yeah! Much too much fun! But then again, mine has been on the track since 2006, and run hard. Learned a few motor building lessons along the way.
FYI, if anyone is looking for a 302 there's a post under the SBF section for a stock 302 disassembled and hot tanked, selling for $400 out of RI I think. I'd consider it if it was closer.
edit: actually in MD, not RI as previously posted if that makes a difference. only 7 hrs from me...tempting.
21 - 24 of 24 Posts
