ff cobra master craftsman
does any one know if you can purchase one 30 lb
injector?, i have narrowed down my misfire on my
342 i believe it is a bad # 3 inj have 200 pounds of comp, checked spark with spark tester, checked
inj connector with noid light plug looks to clean
getting small explosion from right side pipe at times. i do have the ffr fuel cell possibly the powder from the bladder clogged the inj or the injector is bad. can you clean a inj if it is clogged?
I haven't done it myself, but my dad got one replaced on his old toyota pickup. I assume you could do the same for yours.
just another builder
check ebay
Hi Wrench,
I know it's some work, but swap that injector to a different hole and see if that cylinder goes bad and the old one gets better. I think I can warranty that injector if it's truly bad. Call me with the results f this test.
Mike Forte
