1 - 14 of 14 Posts
Does anyone know where I can get 3" rubber hose (about 6" in length needed)for a cold air intake I'm fabricating? It'll be used to connect the long black Mustang 5.0 air tube to a mass air meter on a non-FFR application. I can't find suitably flexible stuff around here. It must be able to flex over a 3 1/8" diameter air meter, and will be attached to a 3" stainless tube on the other side. Thanks!
Did You look in home depot in the plumbing isle? There have some nifty rubber piping. Theres an online company too ill have to dig up the name... Heres a pic of a power pipw we fabed up!
Rgds
Rob
Hi Rob, nice setup! I'm doing the same type thing. Home Depot plumbing and A/C parts are wrong dimensions. The rubber connector w.here your rig attaches between the mass air meter and the silver pipe is the piece I'm looking to find. Has to be 3" on both ends, and able to "flex" enough to fit over the mass air which is actually 3 1/8" OD. I gotta find a ricer shop or something around here, no luck so far! Thanks for the pic and response.
Hey John,
H.D. sell some 3" aluminum flex hose like I used on my fresh air vents, (back wall next to the floor by the screening materials) or Grizzly sells 3" rubber hose. Stop buy and I'll give you a piece of aluminum to try.
Bob Mac
FFR3981
John,
Powerdyne sells the tubing with their blower kit. Give them a call...
Chris
John,
Does it have to have the bellow in it or is a straight piece fine? I have some 3" high pressure rubber hose for superchanger application but I believe it is 3" OD. I'll check to see if it will fit over a 3" pipe tonight. If it will, I'll FedEx a 6" piece out to you.
Thanks for the help you guys. Chris W, the high pressure hose won't work for this application, I've tried some of that I bought locally. I'll check out the other ideas and see what I can come up with. Thanks again for the help.
I think the place Rob got his stuff is www.airflo.com
Hope this helps!
Discussion Starter · #10 ·
Hey Cool!Truck intake parts! I'm going to stop at a truck dealer tomorrow to see if any rubber parts like this are available without ordering. If not, AirFlo here I come! Thanx again all you guys.
John,
How about snooping around a scrap yard for something you can modify to suit. For example this is from a '90 Integra. The end on the airbox is right about 3-1/8 and the tube has an ID of about 3". It is a fairly soft and flexible hose and could be trimmed shorter. With all the different cars out there I'm sure you could find something that is close to what you need.
HTH, Rod
John,
Spend some time on McMaster-Carr's website as they have tons of hose types. Also, check Aircraft Spruce for heavier hose / ducts that can withstand higher temperatures (i.e., CAT, SCEET).
Hope this helps.
Drew
FFR#3928
Has the wife missed the towel yet?
1 - 14 of 14 Posts
