The best pictures I've seen are at FFR's
3 Link Installation page.
How it works:
It removes the standard upper control arms. The stock upper arms are angled in a "V" shape which gives the axle lateral stability at the expense of full-range of travel without binding.
The 3 Link removes those upper arms and replaces them with a single upper arm that points straight forward. (parallel to the driveshaft). This allows the axle to move up and down freely without binding.
However, you have no lateral support to keep the axle under the car. That's where the panhard bar comes in. I mounts to one end of the axle, runs across the car (parallel to the axle) and mounts to a new frame mount on the other side.
This way the axle can move up and down freely, and also have side-to-side stability.
-Joe
[ May 01, 2002, 03:45 PM: Message edited by: DragonSnake ]
