Is this the correct washer for here?
Are there bolts long enough or am I bitten by the FFR too short bolt bug. I torqued this down to 70 lbs. Didn't seem like enough to me
Where are these suppossed to go?
are those spacers metal? I would assume they are, but they look odd in that pic. Maybe the camera. Did you use the 3-link install guide?
I think you might want to add a few more pics with better lighting. Too hard to make things out. Either that or my eyes are worse than I think!! :confused:
Try forcing the flash on your camera to get better detail under the car where ambient light is limited.
Sean
That bolt is long enough; no problem.
Slacker Extraordinaire
Nylon lock nuts torque much lower than standard nuts of the same size. You should be fine. There are a lot of spacers that are really close in length. If you have calipers you can measure them out.
See my sig line
