FFR Master Procrastinator
OK, I have looked at this for hours now, and I figured out that my bracket (drivers side) is backwards. Im not sure if its a recent change, or if its even that big a deal.
Look at the pictures (this is my first time posting pictures, so I hope it works)
I looked at other 3 link set setups:
http://www.doublestripes.com/3_link/web/slides/3_link_1.html
as well at dv/dt's,
and if you compare, my driverside bracket has the lower shock mount on the inside, when all the other brackets have them on the outside.
I doubt that FFR could have made the bracket incorrectly, but it just freaks me out because it doesnt look like all the other ones.
Does anyone have a similar driver side bracket, or is it incorrect.
Thanks for the help.
I believe they have sent you the wrong bracket. It has been some time since I built up my 3-link but I too had a very similar problem and it was a mix-up on their end. Call them and explain, they will fix the problem.
That stinks. I was hoping to have my rear end done this weekend!
Oh well... yet another delay.
Not a messed up welding job but the wrong bracket. Ones for the 3-link and the other, wrong one, is for the 4-link set up which is a mirror image of the other 3-link one. Give them a ring.
Cheers, Rod
Building
Ah that would make sense - Good catch Rod
I was trying to figure out what kind of crack the employee was on when that bracket was welded... but your theory makes sense as well.
Slacker Extraordinaire
The brackets aren't 90* square so it wouldn't have just been welded incorrectly. It would have been bent backwards as well. Man that would be a Friday afternoon job eh!
It's the old swaparoo time. Check your steering rods as well, I had to send mine back for the correct one.
A
I already sent my stearing rod back- it was the wrong one. Any other common shipping errors out there?
