Super Moderator
Since no one makes them that I could find, I’ve decided to make my own from static cling satin black vinyl. First attempt at a template came out pretty good. Will transfer to a clean clean sheet with smooth cut lines. If that works will transfer to the vinyl.
Super Moderator
new member
its a 3m product its plastic cling with a carbon fiber look finish so it will wrap around curves a little heat helps too with some corners
its 3m 1080cf12 adhesive backed comes in a 60x24 piece i paid about 30 dollars for it easy to use trace the spat out cut it with scissors and put on took a couple hours to do
Super Moderator
The second attempt at using PlastiDip to make rear fender spats was a success. The trick is to apply 4-5 costs. Only the last cost make sure it’s nice and thick and wet. Then immediately remove the masking
