I have built a Challenge Racer and need to sell my street car to go racing.
Make an offer for this car.
Engine:
88 Mustang complete engine rebuild incuding new main bearings,new cam bearings,new ARP rod bolts,new Cloyes double roller timing chain and gear, new Melling standard volume oil pump,new freeze plugs,new water pump,new Lunati cam shaft,file fit rings(.016 end clearance), new distributor car and rotor,new coil,new ignition wires,new clutch,throwout bearing,and pilot bearing,resurfaced flywheel,under drive pulleys, 4 into 1 header,new alternator,new AN-10 braided lines to remote oil filter,new 8 qt Champ oil pan,AFR 165 alumimun heads, Crane 1.6 roller rockers,new hardened push rods,new FMS 24 lb injectors,new 65m FMS throttle body, new 73mm C&L mass air meter,new Cobra upper and lower intake manifold,new fuel pressure regulator and gauge, Cobra valve covers
Transmission:
T-5 Mustang, inspected and serviced as follows-
New Pro 5.0 shifter,new steel input shaft bearing,new shift fork bushings,new rear main seal,new universal joints
Rear Axle:
Turbo Coupe rear axle with 355 gear,Factory Five 3 link,newly rebuilt traction loc,rear 5 lug disk brakes,rear coilovers,braided steel brake lines
Electrical:
wiring harness ,Roger Stine conversion,Ford inertia switch in trunk,Classic Instruments Cobra package with reverse reading speedo, steering column turn signals
Radiator:
Mustang 3 row radiator with thermostatically controlled fan
Front Suspension:
Lincoln 5 lug front disc brakes,rebuilt Mustang front calipers,braided steel flex brake lines,manual 15/16 master cylinder, power steering with Height's vavle, new ball joints
Body:
paint is Sikkens white with Portifino blue stripes, all seams professionally filled, removable soft top,spates on rear fenders for chip protection,Cobra R wheels with Kuhmo 712 tires, 5 point harnes installed on drivers side, heat insulation installed under carpet for comfort,heater/defroster, new battery mounted in trunk, fire extinguisher
Misc:
sale includes dyno sheet and all parts receipts, Factory Five serial number 2285,licensed and insured in Missouri as a 2001,VIN # 0000151166
Contact Info:
Gary McDaniel
816 361 6282
913 522 8235
[email protected]
$25,900/offers
