1 - 3 of 3 Posts
What is everyone using behind the dash for multiple connections? 20Amp or 30Amp terminal blocks?
Mike O.
section 8
I didn't use any . The AAW harness came well prepared. I would think that depending on what your connecting 20amp is sufficient . General rule of thumb if the wire is less than 10 gage you should not run more than 20amps through it , so 10gage or less 20amp or over 20amps fatter wire = more amps . You can use the wire size as your guide. Bob
I am using the I-Squared system. There is one wire that is a 10G so that is going to the 30A one.
Mike O.
1 - 3 of 3 Posts
