The frame painting process is a 3-step process starting with Industrial-strength cleaner, then spraying on Metal Prep Treatment, and then painting POR-15 Gloss Black rust preventative coating on the frame. I’m sure some will disagree with this choice, but with the care that has to be taken with powder-coated paint on metal, I feel POR-15 will be tougher and thicker with less vulnerability to chipping or cracking, if done right. Time will tell.
This is where having a family comes in handy. My three children (22,18, and 16) and I are able to move the frame out to the driveway where we put it up on jack stands. After strategically placing the jack stands to minimize the area the jack stands would interfere with the treatment, we rinse the frame down. The temperature outside was about 40 degrees at 3PM, with overcast and no sun, typical Northwest weather in the middle of the winter doldrums. The industrial cleaner takes 3 spray bottles-worth of water/cleaner mix to completely wash the frame down, and I used the whole bottle of Metal Prep rather quickly. I should have had another bottle of it, but I am able to coat the whole frame with the Metal Prep and keep it relatively wet for about 20 minutes. Follow that up with a rinse, and we put some gloves on and move the frame back into the garage to dry off. The Metal Prep chemical is some nasty stuff, and you don’t want to get it on your hands or in your eyes. Using my freestanding propane jet heater, the frame dried off in less than an hour. By now it’s 7 PM, and with the recommendation of the POR-15 folks to have the frame bone-dry when you paint it, I decide to wait for tomorrow to start painting. Tough decision, as the suspension is calling my name and I’m itching to get moving on it. The darker pictures are before the cleaning and coating and you can see in the later pictures that the coating looks like a white stain.
