Too Cheap to paint!
For 15 years I have been using 275/40R17 tires for all track & HPDE driving. Kuhmo V710's and Hankook Ventus Z214's. Both either no longer available or phasing out. So, I'm hitting a critical decision for track tires, stay with extremely limited choices for 17" rims, or go up to 18?
For those of you that use an 18" rim for HPDE/Track, what have you used, and your results/reactions/comments?
I had to add a set of 18" wheels a couple of years ago due to the lack of availability of 17" tires. I run 245 or 255 up front and 315 in the rear. I was able to purchase 2 sets of BFG R1S tires at that time. Sadly they are no longer available in that size. I like these tires for track. Even though they are DOT I wouldn't use them around town, they are just too sticky. I run Nitto NT01 around town on a 17" wheel. The NT01 tires took a few spirited rides to get them softened up. I believe you can still get the NT01 tires in these sizes for a 17" wheel. That might be your best choice at this time - unless someone else has discovered a better solution.
Pro FFR Builder and Moderator
get a set of 18x10's and run 275/35/18's if you run a square setup. Tires are cheap and plentiful and you can call GT Tires and get imsa take offs for a 1/3 the price.
Too Cheap to paint!
Gordon,
Can you provide contact info for GT Tires?
Gordon, that's good to know. I looked into using IMSA take offs a few years ago and the crews all told me the tires were all licensed to them and they were fined if they weren't turned back in.
There are several companies out there that do this.
