Anybody out there have a source for available aftermarket intake manifolds for this engine? If it’s a case where the original heads limit the options, I also have a newer 2004 set of tumble port heads.
Are you using SOHC or DOHC heads? I have some resources I can share with you. Also, how much do you want to spend on an intake?
-M
Discussion Starter #5
4.6L intakes
-M
I'll be using the 2004 DOHC tumble port heads
Not sure on cost so any info you're willing to share would be appreciated.
My initial thought was to go with an 8 stack efi setup, maybe a side draft setup.
But I may just go with FiTech setup for now and go big later.
Thanks for your help
<ole
