FFCars.com : Factory Five Racing Discussion Forum - View Single Post - Missing a cylinder - please help me figure why
post #9 of (permalink) Old 10-09-2019, 01:24 AM Thread Starter
Danish
Danish's Avatar
Thank you for all the suggestions!
Here is what I tried tonight:
Swapped injector wire 7 and 8
Swapped plug 6 and 8
Fired it up and exhaust on 8 was cold
Checked the plug on 8 and it looked wet.
Then got a different plug wire for 8 and checked distributor cap. Tried that. Same result.
Took upper intake and valve cover off again and turned the engine to see if both valves open and they did (I guess if the pushrod was bent and valve stayed close there could still be good compression).
Very confusing.
So if I have compression and fuel, it is ignition. If Cap, wire and plug are fine. I am back to square one.
Next I think I will re-do the compression test and get a different cap for it. Also will try the stethoscope test of the injector if I can get to it (8 buried sits under the intake). Any other suggestions?
Build in progress: Roller [X] Engine in [X] First start [X] Go Cart [X] Body on [X] VIN Number/State inspection [X] Paint [X] Graduation [X] Done with upgrades [ ]
Mark III Roadster, 3 link, 3.55 rear, 302 EFI/w chip, AFR 165 1:1.7 roller, custom cam, 13" front 11.65" rear w. 45mm calipers custom brackets Porterfield R4-S, Dark Blue Ink w. silver stripes
Danish is online now
