post #28 of (permalink) Old 09-27-2019, 04:15 PM
BEAR-AvHISTORY
BEAR-AvHISTORY's Avatar
Am running Forte's cable, don't remember the part number. At 11,000 miles wanted to rasie the pedal engagement point a little more from the floor.
Adjustment seems to go well & pedal is more comfortable.
Found something while testing that I may have not noticed before or was not happening before.
If I hit the throttle about 2/3 3/4 down in 4th at 2200 rpm the tach will jump about 800 RPM then drop to the steady point for the new road speed.
The lower gears 1/2/3 seem to be OK
Is this slippage normal or do I need to try to adjust it out. Clutch is a Center Force single plate.
BEAR-AvHISTORY is online now
