post #20 of (permalink) Old 09-20-2019, 03:12 PM Thread Starter
luey2009
luey2009's Avatar
Originally Posted by RET_COP View Post
If tapping the gas pedal brings the high idle down and nothing is binding then check your return springs on the carb. You should have two springs with enough tension so this does not happen. Glad the Ford Racing cables work nice for you. I put a little grease on the cable in the quadrant area.
yes the idle does go back to normal if i tap the pedal. I actually only have one return spring on the carb, I will add the second tonight. never had an issue with the one on it but 2 is safer.
I just wanted to get your thoughts on the idle not coming down between shifts, being related to or not related to the clutch cable adjustment.
any experiences anyone?
i will add the return spring and test drive the car tonight.
thanks again
luey2009 is offline
