post #17 of (permalink) Old 09-20-2019, 12:08 AM
RET_COP
RET_COP's Avatar
If tapping the gas pedal brings the high idle down and nothing is binding then check your return springs on the carb. You should have two springs with enough tension so this does not happen. Glad the Ford Racing cables work nice for you. I put a little grease on the cable in the quadrant area.
RET_COP is offline
