post #14 of (permalink) Old 09-19-2019, 12:23 AM
teesalmon
Some cables tend to break up by the quadrant. Can you look up in there and inspect? After mine was in the car, i tried to sand the sharp edges of the two pieces that make the walls of the groove in the quadrant. If the cable is not lined up perfectly, the sharp square edges will rub on the strands, causing a few at a time to break. The cable will probably stretch as a result, then eventually break.
teesalmon is offline
