FFCars.com : Factory Five Racing Discussion Forum - View Single Post - 2015 Donor Mk4 Roadster w/IRS, First Build - Input Welcome, Many Questions.
post #286 of (permalink) Old 08-12-2019, 07:52 AM Thread Starter
IsaacW
First Time Builder
IsaacW's Avatar
Before ..... you can see my bend markings, and my trim markings, at the bottom.
After...
Much better fit. No pressure. Check the other side .... how do we fit there?
Looking good on Driverís side. Now that the dash is bent appropriately, we double-check all the holes for fitment. Two of them concern me in particular, the steering wheel and the Headlight Switch. The steering wheel hole is too tall, and I donít want the dash cover dimpling in where there is no backing. I decide to cut a piece of sheet aluminum from my old Footbox front and epoxy that to the dash on the backside. Simple enough. For the Headlight Switch we use an oversized washer and a Dremel with a stone wheel to notch the inside of the washer before epoxying it into place behind the dash. I think it was a layout decision change that resulted in the incorrect hole size.
From the front ...
We let that dry, then filled in the front side with a little epoxy to bring those more flush. After sufficient drying time, we clean the surface with epoxy before Landau Cement is applied.
After triple-checking finished layout and clean surface, we use a 4Ē wide bush to apply Landau Cement to the back of the dash covering and the front of the dash surface. Drying time of 20 minutes is advised and I monitor it for tackiness and sheen. After about 20 minutes most of the two mating surfaces are dry, so itís time to apply. There was a little waviness in the dash cover material; Iím planning on using a roller to firmly roll the material both directions outward from the center. After very carefully lining the dash up with the mark on the back of the dash material, I gently rest the dash down onto the material. After some firm pressing down of the middle of the dash onto the material, I gently pick it up and turn it over. Using a tube of silicone, I start in the center and firmly roll the material outward toward the ends, including around the curved ends. Ok.... material applied, let it dry. Iíll roll the edges over after I cut out for the gauges and can pull those tabs in at the same time.
After overnight drying I mark the cutouts and start notching the dash material for rolling it over. My cutting tool is a simple box cutter, cutting from the backside, and I do have to break it a few tabs down every so often to keep the cutter sharp.
After cutting the holes out, notching them for foldover and notching the material around the edges, I apply more Landau Cement along the edge and bottom of the dash and all the way around the perimeter of the dash material, and let that dry. The stuff is smelly, use in a well ventilated area.
After drying about 30 minutes, I fold over the edge cutouts and press them into place with my ĎRollerí. Itís starting to look better.
After drying time (yeeesh...!) I start installation of the gauges and controls.
Isaac Wilson
Vancouver, WA
Factory Five Roadster # 9513
2015 Mustang GT Performance Pack Donor
5.0L Coyote Engine (Gen2)
Tremec TKO500
2015 Mustang IRS
Wilwood Brakes
18" Halibrand w/BFG Rival S
LED Lights
IsaacW is offline
